- lucytravel12ExplorerOrdered it from Amazon - thanks!
- Dick_BExplorerX2 on the Oxygenics. We have one in our RV and our stick house.
- rekoj71Explorer2X water pressure does happen when the city pressure is lower by either a pressure reducer or possibly just low city pressure. Many regulators are set to 35-40PSI and our pump runs as 55-60PSI so I get the same issue sometimes, but I like the lower pressure as it keeps the wife/kids from using up all the hot water too fast.
X3 (or whatever) on the Oxygenics shower head. It uses a bit less water than most shower heads but by it's design it feels like there is more pressure coming out of the head. They usually come with a separate shutoff valve that can be put on the handle but is optional. The shutoff valve works good too. - Old-BiscuitExplorer III
Johno02 wrote:
We like the Oxyenics, but the best way to get good pressure is to have some water in your fresh tank, and turn the water pump on when you shower. In our case, it doubles our pressure. Also, check to see if there is a flow restrictor in the shower head or at the faucet. Most RV showers have one installed.
Doubles your pressure :H
Then water pump discharge would have to be 2X what the city water supply pressure is.
Might help a little bit with better flow.......but that depends on what pump flow rating is and how restricted the flow is coming into you rig from city water supply
If pump runs it closes the city water check valve other wise it would pump water back into city water supply. (Pump can only come on IF city water pressure is lower than pump pressure switch setting)
Getting rid the flow restrictor in the shower head will be best improvement for showering.
Some have them in hose connection at faucet, some have them in shower head where hose connects.
Some can be pulled out....others are fixed and have to be drilled out (enlarged)....either way simple mod that helps - Crazy_RayExplorer3X for Oxygenics. We also you the in home.
- Johno02ExplorerWe like the Oxyenics, but the best way to get good pressure is to have some water in your fresh tank, and turn the water pump on when you shower. In our case, it doubles our pressure. Also, check to see if there is a flow restrictor in the shower head or at the faucet. Most RV showers have one installed.
- downtheroadExplorer
38,766 PostsLatest Activity: Jan 10, 2026
