Fishinfrank8 wrote:
I have a 2015 Bounder 33C and the show is either cold or hot nothing in between. I ordered a replacement on the internet same quality. Who makes a quality mixing valve for RV's?
You might want to try a Moen valve from Home Depot, Lowes or any of a number of other home improvement stores. We replaced the one in our 2001 Winnebago Adventurer for the same reason.
If Fleetwood is the same as Winnebago they use standard off the shelf style valves. The main difference between those used in a sticks and bricks house and those used in a motorhome is the ones used in motorhomes are made of plastic. The motorhome builders just use an adaptor to connect to the plastic tubing.
Now that tubing is becoming more standard in sticks and bricks homes you may be able to find a replacement complete with the tube fittings. In our case we had to transfer the adaptors from the original valve to the new one.
