- Ro646aExplorer IIIt has a Cummins 330 hp ISC
- JR45ExplorerIf your fan goes to high and stays there your fan controller has gone bad. Mine went out and I installed the wax valve extremely reliable, and more efficient than the electronic FCDA.
As stated change the hyd filters, mine have 3 filter stacked and there is an up side to the filters.
If the coolant has never been changed, something to think about. What motor do you have Cat or Cummins ?
JR - Dog_TrainerExplorer
Bikeboy57 wrote:
Check blades for tightness
Check fan to motor for tightness
Look at blades for cracks
Unplug harness to speed regulator to ensure the fan faults to high speed
Replace fluid and filter if no records of maintenance
Along with all of the above squirt the fins of the radiator down good with simple green let it for a while then use a hose and spray from the back side of the rad outward and flush well. Please do yourself a favor and do not use a power washer on your radiator. - Trumpet_PlayerExplorer
Ivylog wrote:
I would change the filter on the system.
There may be two filters for the system. On our Spartan chassis, there is a spin on filter as well as one in the reservoir itself that requires that the fluid be in the reservoir be drained at least partially to service.
Safe travels. - Bikeboy57ExplorerCheck blades for tightness
Replace fluid and filter if no records of maintenance - IvylogExplorer IIII would change the filter on the system.
- Bill_SatelliteExplorer IIFlush with a hose from time to time. That's about it. I use a pressure sprayer with a wide low pressure output once a year or so.
38,778 PostsLatest Activity: Jun 10, 2026
