bamaboy473
Jun 08, 2014Explorer
eheading wrote:
One easy way to check out the voltage issue is just keep the engine on when working the slides. If you still have a problem, then it probably isn't a voltage issue.
Ed
Thanks, Ed. No, it isn't a low-voltage issue because I'm connected to shore power here at the house, so batteries are all topped off.
Given that Equalizer hydraulics are supposed to be self-adjusting for pressure, I'm beginning to wonder whether there's a pressure valve of some sort that's restricting flow to one of the cylinders?
Of course, that likely has nothing to do with the motor dying, or could it?
38,782 PostsLatest Activity: Sep 01, 2026
