MrWizard
Jun 27, 2018Moderator
depends on the age/year of the fridge/RV
early 70'sand before, with manual igntion on the LP flame
doesn't use any 12v control, doesn't care about battery
from the 80's up the fridge controls need 12v, but use very little power
could go days, if there is NO other 12v use, like the lights, the water pump, 12v fans etc..
brand new battery ? or old battery ?
the fridge control power will be connected to the house battery, from the same fuse control center as the water pump and 12v lights
running the generator, should charge the house/rv battery, and supply 12v to the lights etc at the same time
run it early morning, before things get hot, or late evening after things cool down a little, or in the middle of the day if you need to
