kerrlakeRoo
Jun 27, 2018Explorer
If you just installed one battery I will point out that most folks, especially if they boondock use two.
Is there enough space where you installed the first to add a second identical battery next to it?
If so, and you only installed one, you should consider adding a second, wired parallel to the first.
It's not only the fridge that ran the battery down, use of the water pump, lights, all non driving functions are coming from the house battery, so having the second in place will prove very useful.
