MrWizard
Jun 27, 2018Moderator
the fridge controls are wired to the DC fuse panel
look above and below the fridge for the 110v circuit breakers and the 12dc fuses
your fridge should in no way be connected to the chassis/engine battery
your engine battery should not be affected by RV house systems
does your TV work, without the generator running ?
if the answer is yes, you have a 12v to 110v 'inverter' installed somewhere
fridge could be using that power and will suck your batteries dead
make sure fridge is NOT on automatic
put it on LP use the push button the 'control' above the fridge door
set to 'GAS'
is your fridge the side by side doors, with ice maker in the freezer ?
if yes, open outside fridge access door and unplug the 110v cable marked icemaker, if not marked unplug both 110v cables
set to 'GAS'
