lamoz1
Jun 28, 2018Explorer
MrWizard wrote:
the fridge controls are wired to the DC fuse panel
look above and below the fridge for the 110v circuit breakers and the 12dc fuses
** It's above and all breakers and fuse are fine **
your fridge should in no way be connected to the chassis/engine battery
your engine battery should not be affected by RV house systems
*** checked yesterday and both my house and chassis batteries had drained to 4.5 v. ( jump started the Rv and was getting 14.5v to all batteries
does your TV work, without the generator running ?
if the answer is yes, you have a 12v to 110v 'inverter' installed somewhere
fridge could be using that power and will suck your batteries dead
** I do have an inverter, and will check on that, Thanks!!
make sure fridge is NOT on automatic
put it on LP use the push button the 'control' above the fridge door
set to 'GAS'
*** that's how I've done it
is your fridge the side by side doors, with ice maker in the freezer ?
if yes, open outside fridge access door and unplug the 110v cable marked icemaker, if not marked unplug both 110v cables
*** Yes it is that type I will look for that cable...
Thanks for all the great tips. Will have you posted since I do want to take her camping for the holiday weekend.
