time_to_go_now
Aug 18, 2015Explorer
I just called M&G. They have no option for my 2015 Jeep Cherokee. Depending on your specific set up, you need to install an air tank and a compressor on the motorhome, unless you already have an air source. And you have to break into the rear brake line to install a T-valve. That means bleeding the brakes when you are done. And you must install a 4" spacer between the brake master cylinder and the brake booster of your towed car. Not a huge deal, but, like on my Jeep, there might not be enough room to move the master cylinder out 4". However, sounds like a really nice system if it will work for you.
And I have more than one car I pull behind the motorhome. We pull the Jeep and a rock crawler.
The Brake Buddy move easily between the two cars.
38,782 PostsLatest Activity: Aug 31, 2026
