deprived's avatar
deprived
Slide accident - alignment issues.
Recently we put the slide out not realizing that there was an obstruction (a broom) between the wall and the slide. :S
Now the slide seems to be out of alignment. On the side opposite the broom, the gap between the slide and the frame is too narrow, so the seal keeps coming off whenever we bring the slide in or out.
Are there, as far as anyone knows, ways to adjust or align the slide?
THANKS!!!!
    THANKS!!!!
    Been there done that with a book and the edge of the lounge chair and the cabinet draws left loose. Just take it into your RV shop where they will lift the pressure off the slide and then re-adjust the slide gears. Your broom just knocked the gears from their correct position. Lesson learned---Just before putting in the slides, my girlfriend and I both check that all is clear to bring the slide. I use a bungee cord to hold the kitchen cabinet drawers from sliding out when traveling down the road.
