bamaboy473
May 26, 2014Explorer
vanzuilekom wrote:
Let me know the year and if the slide mechanics are Power Gear.
If it is then I will send you the fix process as I had this happen as well. Never since the simple fix 2 years ago.
Thanks, guys. The owner's manual provided info that the slide is hydraulic, and operated by the same pump that levels the MH (HTH brand).
(note: I also learned that if my coach sits for a week, then enough air drains that the slide won't extend all the way; giving rise to great fear of having to ask an RV mechanic to make a house call) Running the engine allowed air to build to 125 and the slide engaged properly.
I'm going to fill the reservoir and mark the fill line, then see how it is after another trip we're taking this coming weekend. In the meantime, a couple of scrap 4x4s will now support the slide bottom...just in case.
38,769 PostsLatest Activity: Apr 24, 2002
