RVWithTito
Sep 03, 2015Explorer
Slide Out Alignment Tips?
Has anyone adjusted the alignment on a living room slide-out? If so, any tips? I was thinking of attempting it myself.
My slide out sometimes doesn't want to retract. It's intermittent. I suspect it might be a slight binding issue. I can usually push on it to get it started and it goes. One time my son and I had to push it all the way manually. It just started doing it a couple months ago after a weekend when we had a lot of guests in the RV. I lubricated the track and it works better, but still get's stuck every once in a while.
The slide has an electric motor hidden in a sealed compartment underneath. I may remove it this weekend to check it out.
Any guidance is appreciated. Thanks!
