jtfcons wrote:
dougrainer wrote:
We did not start selling Monaco/HR products until 1998. BUT, I have NEVER seen any Monaco product have such a feature. I also have NEVER seen such a feature on the thousands of motorhomes (multitude of brands) I have worked on over the past 34 years and especially since Slideouts have become standard on almost all motorhomesin the past 25 years. What makes you believe your HR has such a feature? There is no good reason to have such a feature on a motorhome. If the slideout is extended and you attempt to drive OFF, then you are pretty stupid if you do not see that slideout in your side view mirrors:B I do believe there are a few brands that have such a feature, but I have never seen them. Where is this override switch located and are you positive that a previous owner did not install it? It does NOT make sense to have such a feature and then have an override switch that negates that feature. Doug
Firstly, the reason I came to the forum knowledge base was to find out whether there was knowledge concerning such systems and how or if it was adjustable. I do not know whether the previous owner (died) installed such an override switch or if it was a factory installed feature. The switch is located in the center console area ie if you pull the drawer out the momentary push button switch is concealed in the drawer cavity area. What I can tell you other than the previous description of the actions that occur is that if you unclamp the travel clamps, extend the slide, return the slide, reclamp the travel clamps, the problem goes away ie the engine starts immediately. I'm not trying to defeat this feature but only trying to adjust the false alarms that I'm dealing with, OK. You know, the use of such a interlock is not that stupid because IF the slide was not secure, for whatever reason, its not a bad idea to prevent movement (no engine start). Yeah its stupid to have that happen, but you've certainly seen worse, right!!!
The reason I posted was to let you know that it is NOT standard for that switch. The fact that the switch is hidden shows the previous owner installed it. Since it is NOT OEM, it will be very difficult for anyone to give you help as the previous owner did all the modifications. I would bypass the hidden switch and not rely on the jerry rigged disconnect. IF a slide is not secure the MOST it will move is about 3 to 4 inches. Doug
