dougrainer wrote:
I was hoping the wires and connections would be labeled. Is there a schematic on the inside of the cover? You stated that you can start the engine with the SLIDE EXTENDED. I thought that was the point of the safety interlock----To NOT start the engine when the slide was extended. Was that a typo? Regardless, I would disengage the system to not affect the engine starting at all. Doug
No schematic. I can only start with the slide extended if the switch (override) is depressed. Sorry, if that was not clear.
As it currently stands, when the slide is in and I can not start, the only recourse is to depress the aforementioned switch. So until I find out why it fails to start with the slide in, I don't see how I can remove that switch from the circuit. If I knew where to look as to how it is inserted or had a schematic, maybe this would be an option. This issue is intermittent, that is, the fail to start with slide in only occurs once in about every 20 starts or so, but is still something I want to trouble shoot and fix if possible because this can't be normal. Said another way, whatever the mechanism is that tells the control the slide is in has a problem that I would like to fix. Like I said before, I've never been stranded, because pushing the switch always cures the fail to start.
