SamplePage 1 of 4
Helpful hints to identify the Slide Out Motor Assembly:
Rev: Apr-11
1. The Boot (Not sold separately) covers the brake assembly. Boots have different
colors such as red, white, black, orange and gray. Usually the boot color
indicates the torque rating of the motor assembly. Gray (low torque), Black (high
torque to ultra torque) and White (ultra torque). This is a visual help when
identifying a motor assembly and does not guarantee the torque rating.
2. The Brake Lever (Not sold separately) is under the boot on the end of the
motor assembly and is proprietary to Power Gear only. This should be in the
engaged position (see label on motor housing) when operating the motor
assembly.
3. The Motor Housing (Not sold separately) holds the labels for identification of
the brake lever (engaged or released) and the Power Gear part number label
(p/n= part number) and the base motor label located on the opposite side of the
Power Gear part number label. The circumference of the housing can vary from
diameters such as 2 ½” to 3” and larger; however the larger diameter does not
indicate higher torque.
Boot
label location step 6
Motor Housing and
Gear box and
label location
step 6
Output Shaft
Brake
