jy
Jul 08, 2017Explorer
slide out operation
My friend has a 2008 Damon MH with 2 slide outs.when parking at a campsite the motor must be shut off before the slide outs will extend.After they are extended the motor will start and the MH can be d...
Bruce Brown wrote:wildmanbaker wrote:
It does seem strange that the slides will not operate with the engine running. It would seem to be hard on the slide out systems to not have good voltage and current to operate the systems. Just like most leveling systems require the engine to be running, park brake on, and trans in neutral to operate. Dougrainer has had more experience with these systems than I, to I would side with him.
On a diesel you wouldn't want the engine running while trying to level, it would keep building air while it needed to dump it. On ours I manually dump the air while it's running, then level.
As noted, the slides will not extend or retract if the key is on. You do need the key on to run the revelers, just in the accessory position.
