georgelesley's avatar
georgelesley
Slide out rails
We have a 2914 Itasca Sunove 33C with Schwintek slides. Since there are four gear driven rails, two top and two bottom on each side I assume are there in fact four motors total to be lubed.
I have watched a YouTube video on how to lube the motor coupler and the "gibb" as it is called. Hard to know if you are spraying lubricant in the right place for the motor coupler. The "gibb" can be seen and so is easy to lube, the motor no so easy. Any hints?
  • dougrainer wrote:
    2 Motors only and they are always mounted at the top. You are lubing the "Gib" the plastic slide. You are NOT lubing the motor or the gears. Also, use ONLY the CRC lube, nothing else. Doug
    That is what I wondered. I now understand that there is a long shaft from the motor to a gear on the bottom of the shaft. The gear Assy should need no lube, just the gibb. However on the top (of course) the motor has a coupler and according to the video needs to be lubed, not quite as easy as the gibb's
    I have the CRC lube and only use it and have found many other uses for it
  • 2 Motors only and they are always mounted at the top. You are lubing the "Gib" the plastic slide. You are NOT lubing the motor or the gears. Also, use ONLY the CRC lube, nothing else. Doug
