Veik wrote:
As I am looking around, I toured a few used Class C that have slide outs. 30+ft class C's I have seen could have up to 3.
My question is - are these a real hassle the maintain, fix and keep going? Rubber seal drying up, water getting inside, etc.
I know that they open up and create a ton of room while camping.
Share your views, please.
Anytime you have something extra or mechanical, there is the chance for something to go wrong. Yes, you need to lubricate seals and etc, but it's not a hassle. Should be a part of your routine maintenance, such as checking your seals and etc. Will water get in? It could if not sealing correctly. But if the actual slide on the unit is working correctly, then no, it SHOULD not leak.
