Markiemark32
May 03, 2016Explorer
Slide Topper - Help
Accidently got to close in my RV carport, and snagged the slide topper on carport.
Along with rubbing the fabric, I snagged and bent the pictured lever:
It appears the lever is held in with one screw, so I can remove and fine a replacement, I ASSUME.
Does anyone know what that lever/arm does in respect to the slide topper?
If I remove and run the slide out, will it have an effect on the proper use of the topper?
Thanks in advance, for any insight!
Thanks,
Markiemark:C
Thanks,
Markiemark:C
