DSDP_Don
Apr 19, 2014Explorer
tmmar.....The fabric is attached to the drip rail on the side of the coach. Often, it is held in place to keep it from sliding front or back by a screw at both ends. You might try removing the screw at the end that is wrinkling. Pull the material a little (away from the slide and then try moving the slide in and out. If this fixes the issue, reset the screw.
38,764 PostsLatest Activity: Dec 23, 2025
