tropical36
Nov 12, 2020Explorer II
I found a way for making it a simple one man job and have done two of mine so far.
Put the slide about half way out where you have some room to work. Then, take up a little slack and C clamp or other, on the opposite side of where you'll be removing it. Then use a drill for widening the slot towards the end of the roller on the other end. Spray the whole slot with some slickum, like silicon and after removing the track anchors on the coach body, slide the thing out, little by little. Clickity....
