dougrainer wrote:
mike brez wrote:
dougrainer wrote:
Gazelle05 wrote:
After checking hydraulic pump and finding out its fine also leveling jacks work. Starting to think bad ground as was mentioned in a previous post might be the issue. Question is how do you isolate a bad ground?
Thanks for all your advice it is appreciated.
BAD GROUND. This is a term that drives me nuts. After 38 years as a Tech, BAD GROUND is a thing that is so rare, I rarely even contemplate it as a cause. BUT, it sounds good when you have no clue:B IF the Pump is working, your grounds are OK. You have a switch/wiring/control problem. Since ALL 3 slides fail to activate the pump, you find the central control system for the slides. What Brand Jack system and Slide system do you have? Doug
Sorry Dick I mean Doug...but when my slide would not come back in it happened to be a loose battery ground and guess what the pump still ran I guess their wasn't enough connection for sufficient juice.
Well MILLIE, the OP stated his jacks ran which means he had good power. So, he did not have a loose battery ground. READ the posts and comprehend the posts before posting. Doug
Well Dick I posted that before he said his pump worked. Talk about not comprehending ...but nice try.
