shesha14's avatar
shesha14
Slides on Gulfstream Endura not sealing
We purchased our 2005 Gulfstream Endura earlier this year and have had issues with the bedroom slide leaking, it closes all the way on the bottom but not on the top. We've had it looked at and they say there is no way to adjust these slides. I called Gulfstream and they say it's a "liftco" brand but didn't have any advice on how to fix it,anyone have any luck adjusting these?
Thanks in advance
  • I had my front slide adjusted on my 2007 Gulf Stream in order to seal at the top.
  • There are adjustments. My model is 6340. There are 4 rollers mounted on the wall along the bottom of slide. These may have come loose from wall. Access to slide mechanism is done by removing mattress and platform that it sets on. You will find adjustment for attachment to slide walls and cylinder that moves slide in and out. Report back with what you find.
