mhbell
Aug 11, 2015Explorer
Gjac wrote:I am sure that is most of the problem although some of the felt is missing at the rear vertical track of the window. I remember reading somewhere where they drilled some extra holes to help solve this problem.
I just checked mine this morning after a hard rain and the same thing happened. I have cleaned the weep holes numerous times with a knife blade and removed the felt /rubber track and cleaned under it because mold and dirt build up under it and plug the weep holes. I just cleaned it 5 weeks ago and was amazed how much mold grows under the track. Has anyone replaced the track, and if so did you have to remove the sliding window?
38,773 PostsLatest Activity: Apr 25, 2026
