path1
Jun 11, 2018Explorer
Don't seal weep hole drains, just make sure they are clean so they do as intended...let the water drain out.
I would pull a screw at top on each corner and see if they are little bit rusty or a hole bunch rusty. If a bunch of rust, could be time to re-seal the window FRAME (not window to window frame, but window frame to the window cut out in the rv) Lots of youtube vids if that's the case.
38,769 PostsLatest Activity: Mar 30, 2026
