rgatijnet1
Oct 12, 2014Explorer III
Next time it does this try your boost switch and see if the engine starter cranks faster with the extra batteries in the circuit.
I know that GM engines had a problem with various exhaust components being close to the starter and over time that heat tends to affect the starter operation. I don't know if Ford has this same problem but if all of your batteries doesn't help the starter you may want to check to see if it is getting hot from your exhaust system routing.
38,777 PostsLatest Activity: May 24, 2026
