SkiMore's avatar
SkiMore
Explorer II
Sep 27, 2014
small bathroom ideas
I was at an RV show today and saw this dry bathroom in a class A. It was very compact and looked like a great answer for a B or C. It was in a Thor. I think this was it, but it looks bigger in this floorplan than it was in real life. The shower was very small and had a curtain instead of doors. There was very little wasted floor space. The door opened to close off the hallway to give you plenty of space to change.
  • SkiMore wrote:
    Do any brand TTs do it better than others?
    REALLY small TT's often have the tanks in virtually the same location- fresh above, used below; or side by side.
    And now that I think about it, this is another weird thing that most floor plans lack: location of holding tanks! Seems to me that can make a difference even in some bigger units...
  • Francesca: I didn't get inside the shower. I should have. It's probably a bit too square for a true B. Maybe it would work in a widebody or a small C. If you lost/moved the sink it might work on a standard B. It seemed like a better use of space than the bathroom in a pleasureway pursuit.
    It would be nice if they had dimensions and things were drawn to scale. Based on the size of the bed it looks like it is about 38" x 48"
    tatest: Is this bathroom any harder to find tank locations for than other Bs with a bathroom in center?
    I wondered about the weight distribution thing as fresh drains and black/gray fill. How is that resolved on any RV? I guess it makes less of a difference on a heavy A/B/C than on a small light TT. Do any brand TTs do it better than others?
  • It looks like a four foot space, not too hard to find behind the axle of a C or a short wheelbase small A. In a B there will be a little more to finding a space for waste tanks, depending on chassis and fuel tank and filler location. I see that configuration fairly often in small TT's, only for those it is in a rear corner, and they often put fresh water tank at the other end for balance (which is kind of screwy if you think about weight distribution changing as the water gets used).
    That would be the Axis 24.1, 25'6" long, 94" wide, on a stretched E-350 bare chassis. Most Cs are somewhat longer, might be 8" wider, and can carry another 2000 pounds than this thing Thor calls a RUV.
  • Did you get inside the shower and sort of test it for 'feel'?
    And, sorta off topic, but I've always wondered: Why aren't dimensions included on floor plans???? If the above pic's an "A", it's likely an eight foot plus wide rig. But on a B...25% narrower!
