dlt123me's avatar
dlt123me
Small Leak Caused Wallpaper To Warp & Buckle
I have a small leak in my MH and it has caused one panel of my wallpaper in my bedroom to warp with rolls and waves. I am fixing the leak first then tackling the wallpaper afterwards..
I am wondering what to do, since I will not be able to find a replacement wallpaper to match the existing paper I've been thinking of ways to fix that strip of paper. I'm asking for ideas of what to do without taking all the paper down and putting up new WP all around.
I've been thinking of taking down that one section of WP and running an iron with low heat over the waves and warps to iron out of the wallpaper then putting it back up. Can you iron wallpaper, on very low heat, to take out waves and warps?
My concern is that I will possibly tear the WP if I try to take it down... It's only one section and the seam is up from the wall, so I can slip some glue behind the wallpaper if I decide to not take it down and iron it while in place on the wall.
What do others think, is there a better way to fix this or should I strip out that section completely and replace with something else... such as a fabric or lining? Is my ironing idea crazy?
Of course I will wait till the inside walls are completely dry before trying to re-glue or iron the paper.
Any help is appreciated.. Thanks,
Dennis
________
  • My experience: I had such a leak...apparantly for a long long time (years) that did not manifest itself until last fall when I put my hand on the wall...for some reason. The wall (from the entrance door to the windshield (passenger side) was completely a "squish-squish" thing, and deformed. No repair...had to replace. My dealer of purchase did the job ($2000) and got replacement "wallpaper" that is so close to the original, that unless one looks closely, well, it is that kind of great match. (The leak came from the front cap. but only on the passenger side. Driver side is OK)
