Raymon
Nov 20, 2014Explorer
How are the plates attached to the floor? Are the plates removable? If they are removable, how large is the opening in the floor? If removable, I would remove them and using liquid nails or equivalent, glue a piece of sheet metal over the holes. The sheet metal thickness would depend on the size of the hole. This would seal the floor; then you can install the new carpet.
Obviously, you do not need the holes. I would keep the plates just in case there would ever be a slight chance they would be needed in the future. Let us know how you make out. Wishing you the best.
Ray
Ray
38,766 PostsLatest Activity: Jan 10, 2026
