bobndot
Oct 24, 2021Explorer III
bobndot wrote:toedtoes wrote:
I'm not sure with newer MHs, but in the past, seatbelts have often simply been bolted to the plywood base of the dinette and couch seats.
I suggest you lift the cushions and check.
I did. My belts are chassis mounted in a non slide dinette. When I checked, the seatbelts were bolted to metal framework below.
It just sounds so weak to me, I can't believe that rv building codes allow it. Plywood floor as part of the base structure seems more secure than the floor of a moving in/out side. That slide is held in place by a track that's bolted or screwed to the slide framework. It really doesn't take a whole lot to pop a slide 'out'.
To make things worse, wet rotted wood that you are not aware of would weaken that slides frame.
I've been there when one kept going out onto the garage floor in a friends shop. Owner had no idea it was leak damaged rotted wood supporting things.
