CapeDave
Sep 23, 2019Explorer
Gjac wrote:
I would take it on a 20 mile ride then pull into a parking lot and shoot each tire and rotor with an IR gun from HF ($19 with a coupon if you don't have one) if you find that one of the rears are much hotter than the front ones your rear brakes are dragging or sticking. If so clean and lube the caliper. If you never had the brake fluid changed now would be a good time to do that also.
DO NOT DO THIS! /\
You have a problem that needs to be identified and repaired.
The flex hoses in the brakes could also be causing problems.
38,780 PostsLatest Activity: Nov 24, 2017
