P3TC
Jul 01, 2015Explorer
snake skin
Found an 18 inch snake skin under the dining table that has been shed in the last month. Leaving in the next 2 days for a short trip, havent told the DW. I think it will leave once it wipes out ...
Mr.Mark wrote:GMandJM wrote:
I just asked G-half if he'd tell me if he found a snake in the camper. He said I'd be able to tell from the screaming and him scrambling for the door. (It'd be a race, actually. We have copperheads here.)
We had a snake stuck to a glue board in our garage after the glue board caught a shrew that was probably after the spiders on the board.
I can't recommend using glue boards to find/catch snakes. But if you DO, be prepared to peel it off the glue board to return it to the wild. It is NOT fun for any entity concerned.
We also use the glue traps in the garage. We have never caught a snake but I have caught a couple of birds when I had the garage door open. The house is on a mountain side which is in 'critter' territory.
In the past, we had problems with mice coming in the garage and they don't mix well with engine wires....hence the glue traps.
The way to remove a critter that doesn't belong on the trap is to put vegetable oil on it, the oil neutralizes the glue.
MM.
