David0725 wrote:
I hope I can explain this..lol WE were dry camping all Friday and Saturday. I ran the generator everything ran great all weekend. we were at a R/c racing event. so getting ready to leave I started the RV Diesel PUSHER btw. went in to say buy and realized there were 2 more races and friend was in. so I turn off the Rv and kept Gen running. when is was time to go the rv wouldn't start at all. nothing click click like a bad battery x2. So tried to use the auxiliary battery button still nothing. the shift pad didn't even light up? but all the gages came on and head lights would work. So playing with the key it seem to get a light on the shift pad some times. But now the GEN SET turn off and wouldn't start back up again. what does the key or the rv main battery's has to do with the gen set? Anyway after many attempts of trying everything I can think of Me and my grandson got it to turn over 1 time then click. SO then we held the auxiliary button and the gen set button at the same time and the gen set would stay running let go of the auxiliary it would shut off. we ended up him holding the auxiliary button with the gen set running and I tried to start the rv Yay it started!!! so we took a chance and drove home about 30miles go to the house turn off the rv tried to start it DID NOT TURN OVER AT ALL. Ok now today 4/13/15 I checked the battery's with a lode tester it show weak but not bad. I then tested it with a Meter both showed 12.8 but still say weak. after charging them they show 13.8 on both but still said weak under the lode tester. checked all 3 of the couch batter's same this 12.8 ok under a lode. now after a full charge only like 20min the RV started right up. turn off and on starts right up. Did seem like there was a little drag. So I still don't know why this happen to start with. and why would the Gen set turn off when the key don't need to be on for it to run. And once its stared its not pulling power from the mean battery's right? I thought for sure I was buying new Battery's today. Now im not sure what to think.
First thing to do is step away from the keyboard and take a deep breath...now breath out. :B
Then as Executive has said, "clean, recrimp and reinstall" each ignition wire connection. Follow this good advice.
Travelon
