bumpus4 wrote:
Air pressure front and back is about 60-65psi. maintains pressure very well .
This is your problem... surprised you even get it stopped. Has it always been this LOW? The governor is usually located near your radiator/ back of the engine. By taking off the black rubber cap and loosing the jam nut (3/8") you can turn the shaft with a straight slot screwdriver two turns CW and see how much that raises your pressure. You can do this with the engine running and someone watching the gauges. You want 120 psi minimum.
