RoyB
Dec 22, 2015Explorer III
Of course once the batteries get drained down to absolutely nothing like described here they are damaged and will never be the same after that... Most often they need replaced when this happens...
Sometimes a complete disconnect by removing the ground terminal is the best approach instead of relying on disconnect switches. A fully charged battery will sit fully disconnected on the shelf or in the battery box for a long time and not drain down or freeze up.
Using a multimeter across the battery terminal is a great way to determine if they are being charged. The normal fully charged DC VOLTAGE of 12.6-7VDC will show an increase of 13.2. or 13.6VDC when being charged. Certainly takes the guessing out of the procedure using a multimeter...
We watch our batteries like a hawk when using them and when in storage as they are just too expensive for me to not do this...
Roy Ken
Roy Ken
