WesternHorizon
Apr 10, 2018Explorer
time2roll wrote:WesternHorizon wrote:That is a WFCO and notorious for just charging at a fixed 13.6 volts trickle charge. Unless you actually see voltage steadily climhttp://www.bestconverter.com/9200-148-Volt-Deck-Mount_c_227.htmlb to 14.4 volts by some miracle that WFCO will chronically undercharge your lifeline.
Sorry, I meant UltraIII upgrade kit
http://www.bestconverter.com/45-Amp-Converter-Replacement-Kit_p_46.html#.Ws2G3IjwZEY
If it is fairly new verify the operation and call Randy to swap for an 80 amp Progressive Dynamics with the Wizard controller.
I don't think the ProgDyn's were even listed 4 years ago.
May be time to send BestConverter another $200+.
Will this just slide into the bottom of the original Magnatek enclosure? The Ultra III did include a fuse board upgrade.
