time2roll
Apr 11, 2018Nomad
The 9280 might be too big for the slot. Get dimensions from the link and measure. Allow space for the wire connection. If you have space you can mount it behind the panel. I recommend #4 wire for the entire charging loop regardless of converter. (don't forget ground connections at the converter and battery)
If the converter must fit in the slot there is a PD4655 that will work.
http://www.bestconverter.com/4600-series-Upgrade
Possibly just get a whole new panel. Get the 60 amp.
http://www.bestconverter.com/4000-Series-Compact-Power-Center
As for battery I recommend Lifeline to match what you have and to match charging specs for all batteries.
