RoyB
Jul 22, 2015Explorer III
Solar panels are a two-edged sword. Everyone thinks "Hey I can just add a 100WATT SOLAR PANEL and it will solve my battery charging problem when camping off the power grid."
A typical 120WATT SOLAR PANELS will only provide 5-6AMPS DC CHARGE when in high SUN. If your 12VDC items draw much more than the 5-6AMPS then it won't be a whole lot of help keeping your battery charged.
I am doing my camping off the power grid in baby steps. I immediately upgraded my off-road camper with smart mode charging capabilities and added more batteries and larger battery cables etc. I also converted my OFF-ROAD trailer with LED lighting to really cut back on battery usage...
We beefed up the batteries to run all of the things we wanted to run when camping off the power grid and then used our 2KW Generator each morning at 8AM to power up the off-road trailer so that the on-board smart mode converter/charger would re-charge our battery bank in a three hour generator run time. Where we camp we always run into the problem of the campground seems to always have generator run time restrictions so we have to run it during those times.
Now that we have established how we want to camp off the power grid and can re-charge our batteries in a quick three hour time frame each it is now time to add some solar panels to cut back on my generator run time requirement. There is always times when you don't have good HIGH SUN too so having the generator is really a must have thing to have as primary for battery charging.
We will run down our battery bank to its 50% charge state by 8AM each morning so we now have to recharge them back up to the 90% charge state before we use them again the next evening/night time frame. If the batteries are not at their 90% charge state they will not hold the almost full performance through the night.
When I first hit my battery bank with 14.4VDC smart mode charging they immediately draw 52-53 AMPS DC from the on-board converter/charger unit. This current draw will eventually drop back to around 8AMPs in 30 minutes or so and remain around that level throughout the remaining three hour charge period. I will have to run the generator during this initial high current drain period but then can turn it off after lets say one hours time and then let the SOLAR PANELS finish my remaining charge for the rest of the high sun day. This is the only way I can see to "FOR SURE" get my batteries to their needed 90% charge state before the high sun goes down.
As you can see there is more to charging your battery then just adding a 100WATT solar panel.
Now if you only use a couple of LED lights over night then you could probably pull it off. We like to use almost everything we have available to use with the exception of the Air Conditioner and high wattage Microwave. My other hobby is HAM RADIO... Everything else gets used just like we do when we are camping at regular electric campgrounds.
Just my thoughts and experiences here - It does take some planning on what you are going to do when camping off the power grid.
I am just now thinking about adding solar panel and I really like the folding panel idea to start seeing what I can do with solar panels. For my OFF-ROAD POPUP I am probably only going to room on the roof for two 120WATT panels on either side of my fantastic fan installed on one end and maybe a larger 240WATT Panel on the other end between the roof air conditioner and the end of the roof. I will also have the extra weight added for the panels to be considered. Might have to raise my POPUP roof first then do a quick snap-in quick mount of the solar panels. My 12VDC motor may not raise my roof with the added weight?...
It might be a four sided edge sword for me haha...
Roy Ken
Roy Ken
