KD4UPL
Mar 31, 2014Explorer II
You would normally only need to fuse positive battery wire. The fuse size would be determined by the wire size. #10 needs a 30 amp fuse for instance.
A 200 watt system, depending how it's configured, could deliver up to 17 amps into a battery. I would want at least a 20 amp fuse or larger. That would require a minimum of #12 wire.
38,782 PostsLatest Activity: Sep 19, 2026
