casefarmri
Apr 11, 2017Explorer
Solar panels to keep coach batteries charged over winter
I am trying to get info on what size(watts, amps, volts)solar panel I would need to keep coach batts charged. I am only able to store coach at end of street at private lot an there is no outlets. Went to use slides and could not open due to batteries at 6v vs 12v. Started motor and gen to charge and they came up to 12v.
I would like to put a small solar panel on roof with suction cups to charge coach batts. The factory panel on 07 Fleetwood Revolution roof seems to be crapped out cause sure doesn't charge.
What specs are needed for basic charge and do I need a battery minder to prevent over/under charge or can I elim that? I have 4 coach batteries.
As always the experts are out there. Thank you.
