time2roll
Dec 21, 2019Nomad
13.0 to 12.1 is a significant drop while connected. Either the battery is not full or they are shot. What is the programmed peak absorption/bulk voltage? How cold is it?
13.0 down to 12.65 while disconnected from the RV seems to be in good shape. Although the batteries could still be weak.
13.0 is a bit low for a float voltage in Winter. Is that the programmed voltage or is that late in the day with minimal solar power drifting down to sunset?
Does the controller support temperature compensation?
For now I would let the batteries set with the disconnect switch remaining in the disconnected (off) position. Need to figure out the programmed voltages before you get new batteries.
How many watts are the panels rated?
