KD4UPL
Sep 03, 2018Explorer II
If your batteries really say 20 Ah then you have some unbelievably small odd-ball batteries. Most 6v RV batteries are at least 220 AH.
Solar panels are basically a commodity, shopping should be done on a watts/dollar basis. The larger the panel the better the price. Most larger panels are selling for well under $1/watt. When you start buying little 80 or 100 watt panels you will often pay $1 to $2 per watt. You could probably get a 300 watt panel for $200 or less. I just bought 30 290 watt panels for a job and they cost me under $150 each but that's a wholesale price.
The charge controller, wiring, mounting hardware, etc. will cost you more than the panel. You might as well put up two or three. I just did an RV recently, I installed 3 290 watt panels. The whole job cost the RV owners about $3,000 for a turn-key installation. The 870 watts of panels only about 1/6 of the cost.
