time2roll
Sep 03, 2018Nomad
4x GC2 is about minimum. You could go 8x if needed. Plenty of posts from users with 500 watts solar and still need to run the generator. So 600 to 800+ watts solar would not be too much.
Hopefully you have an inverter/charger that can push 100+ amps into the battery when the generator does run.
If you really want to go big on this consider lithium batteries.
www.solarblvd 255w panel $140
Plan to pick these up or shipping will kill you. Norco, CA. Or local supplier should have similar.
