rcmiller32
Aug 31, 2014Explorer
I would look for a large HD starter solenoid between the chassis batteries and the main starter solenoid. Most times this was closer to the batteries and then a heavy cable would run to the starter solenoid. Also check all the battery and solenoid connections closely for corrosion and dirt. Last I would check out for a possible defective neutral safety start switch or relay.
38,782 PostsLatest Activity: Sep 10, 2026
