Tinstar
Sep 01, 2014Explorer
I'll check voltages at all the post but from checking yesterday, there will be NO voltage at the S (start) terminal on the start solenoid until after 8 or10 seconds. I crawled from front to back underneath it yesterday and there is no damage to the start wire anywhere along the way. I repaired the damaged 20amp fuse holder and replaced the ignition relay. I cleaned the ground wire connections and the solenoid works as it should or at least it does when 12volts finally reaches the S terminal,,, which takes 10 - 12 seconds. I read yesterday that the MD3060 Allison does not have a neutral control switch.
If the voltages read OK (and I think they will) at the terminals, does anyone else have any suggestions. My only alternative is to wire a push button starter. I would just run a new wire to the solenoid, turn my ignition to run and then push an aftermarket button.
38,782 PostsLatest Activity: Sep 10, 2026
