myfaceExplorerJan 12, 2020SOLVED No 12VI do not know how, but I lost all 12V in coach. I have 12v when the gen is running but if I turn off gen the 12V is off. I can not locate master switch - if any.
dodge_guyExplorer IIJan 12, 2020Follow the battery wire. There should be a 30A circuit breaker in line along that wire. It probably tripped.
Related Content[SOLVED] 3 way fridge won't run on 12vMystery 12v/30 amp plug - solved12v wire thickness12v? 24v? 36...48v????Is 12V supply wire to USB outlets rated for 15A?
