myfaceExplorerJan 12, 2020SOLVED No 12VI do not know how, but I lost all 12V in coach. I have 12v when the gen is running but if I turn off gen the 12V is off. I can not locate master switch - if any.
ksg5000Explorer IIJan 13, 2020Google "auto reset circuit breaker" - doesn't look much like a fuse/breaker and easy to overlook. If you discover one check for continuity.
Related Content[SOLVED] 3 way fridge won't run on 12vMystery 12v/30 amp plug - solved12v wire thickness12v? 24v? 36...48v????12v Refidgerators
