ron_dittmer
Aug 16, 2016Explorer III
tjfogelberg wrote:For the OP with 3 adults traveling, each wanting their own bed, I favor the 22R. With the shorter 23'-10" over-all length, they should be able to get by without a tow vehicle. The only issue with the 22R are the water/waste/propane capacities. Three adults will need to take navy showers to make it work without hook-ups. And so little a propane tank would be an issue if doing high altitude and Canadian camping where the furnace is used often at night. Also, it is not clear how much cabinet space there is for 3 adults worth of clothing and such.
The smaller Winnebagos are good choices. 22R and 25B both VG. Counter space is very limited in the 25B but you could put inserts over 1 or both sinks and also get a folding cover for the stovetop. The 3 sleeping areas (actually 4) in the 25 B are amazing for an RV only 27' long. Read all the good info here carefully and you'll do fine.
But still a very nice floor plan.
For Phoenix AZ, be sure to get a very light colored exterior to reduce radiant heat.
