wolfe10
Feb 06, 2022Explorer
tourusa wrote:
.... and listen at start up for any tap....
Not sure "listening for any tap" on start up is a good indicator of whether valves are out of adjustment.
If a valve is tight, it will make no noise at all.
Better to verify that the initial valve adjustment has been done, or have it done.
Other suggestion-- clean the front of the CAC. This should be done annually.
Also verify that the crankcase breather (aka slobber tube) has been extended to behind the intake for the fan shroud.
