gbopp's avatar
gbopp
Southwind not starting
1996 Southwind, P30 Chassis, 454 engine.
It was starting normal until about a week ago. It acts like the battery is dead, it will not turn the engine over.
The chassis battery and the house batteries are charged. I tried to jump it with my truck, it made no difference.
It holds a charge after sitting overnight unplugged from shore power.
I did not have the chassis battery load tested, I did put it in my truck and it started several times with no problems.
The test switch on the master control panel shows the chassis battery is low and the house batteries are completely dead.
They are fully charged.
I had a problem about a month ago but, that turned out to be a bad lug on the chassis battery.
It was working great, now I can't get it started.
I was thinking bad ground? Other than that, what should I check?
Thanks for any help or suggestions.
